WD brake shoes
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: WD brake shoes
    Posted: 28 Oct 2010 at 9:57am
I had to take my WD tractor to a shop to get the brake pins removed with a torch because they're in there solid.
He says he'll have to ruin the metal brake shoes, or brackets or whatever you call them, to get them out. Do you know where I can get some? I already got the linings - I need the metal parts that the linings attach to.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 10:38am
Outside of a tractor that has never seen inside there is no reason to ruin the shoes to cut the pin out. Tell him the pin is almost always stuck in the outside hole, not the inside hole next to the housing nor in the shoes. You cut the middle of the pin out from the bottom access hole, (leave enough of the inside pin to grab with vise grips) Then using a drift beat the outside part of the pin in til it touches and cut again, If the pin wont move heat the casting and it will. Then repeat until enough is cut off that the outside part falls out. Then grab what is left on the inside with the vise grips and you should be able to wiggle it out. You may have to cut it again to get it short enough to fall out. All of this can usualy be avoided to begin with by heating the outside pin boss in the casting  while using a properly built puller BEFORE the end of the pin is mushroomed by beating on it.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 12:41pm
Ditto what Butch says but if you need shoes we can provide them as well as the pins. S>L>I
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 5:38pm
amazing trick!  Hope I can remember that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 6:00pm
Like what Butch said.   I ruined the first side the first time I ever did it, but then I learned and did a good job on the second side.   I might have an extra set laying around here if you need some.   I'll take a look after dinner and see if I have any in the shop.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 6:37pm
Butch is 100% correct!!! Ive done several, also suggest doing it outside as there will be smoke from the 50 years of mouse nests .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 6:41pm
would a sawzall get it?
Vinnie/S.D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vinnie/S.D. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 8:40pm
sawsall will do it better then a  a fire it the tractor
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 8:03pm
        Just did one today like Butch said. It works great on mine.
                                     John Carlson
kollmangr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kollmangr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 2:40pm
Butch,
   You mentioned a properly built puller.  I have not ruined mine yet, and would like to use a puller to get them out.  Is there any particular brand of puller that will pull them out?  Or do you have one for sale?  Or can you give me some ideas on how to build one?
Thanks,
   Gordon
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 3:04pm
See on the bottom of this webpage.  Gary makes a puller that grabs the outside of these pins:
This is a link to a similar discussion:
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 9:18pm
If the pin is loose enough the puller will pull it, then you don't need it. Have tride it in years past.
 Drill a hole the same size as pin in a piece of 1/4" steel 2' long slide over the end of pin and weld it.  Work it back and forth with pennitrate oil on it. If it don't move twist the head off and get the cutting torch.
 The puller will only pull the head off if it is tight.   MACK
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2010 at 8:54am
I like the Sawzall method, as well. Haven't tried it but I intend to if I run into a problem pin in the future..
 I believe there will be many cases tho,  where a torch will still be needed
to heat up the casting before the pin will move.
