Allis Forklift Zenith carb question
alRCRVRP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alRCRVRP Quote  Post ReplyReply Direct Link To This Post Topic: Allis Forklift Zenith carb question
    Posted: 13 Mar 2024 at 7:42pm
I have a Allis Chalmers fork lift  model FP-40-24  with an overhead valve AC engine.
The carb on it is a Zenith.
Numbers on carb are as follows.
6-95
13153
4515463
It runs a bit rough on acceleration.  I have  replaced the plugs, points and condensor and adjusted the horizontal idle screw on the side of the carb so it idles well. Adjusted the timing by ear, almost impossible to get a timing light in there.
It still stumbles a little on acceleration, not bad but noticable.
I has thought there was a high speed adjustable jet coming out at an angle on the bottom of the carb bowl but there is only a hex headed plug there.  Another hex head pointing straight down.
 Is this a carb with a fixed high speed jet?
Any suggestions for me?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2024 at 6:41pm
Yes, some of the older carb applications had a fixed main jet. I have one on my old Allis B tractor. It works great, you may have to clean the carb if it seems to run lean at higher speeds. I feel that the fixed jet is slightly on the generous side, better that way for me than running lean.
Braswell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braswell Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 6:03am
Check the spark… the (secondary ignition spark)..
If you hold the coil wire close to a ground and spin the engine. The spark should be blue, fat, 1” long. If you have graphite core spark plug wires change them to copper core, if you already have copper core wires and still have a weak spark ( thin yellow) then look at a new coil. If you still have breaker points look into Pertronix Ignitor kit and upgrade the ignition. It’s $100 not counting the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alRCRVRP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 8:42am
Thank you for the replies, I'll check it out further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 6:59am
As with most all older carburetors when trying to run them on "todays' gasoline they need to be richer. Almost all of todays gasoline is "oxygenated" in some manner to comply with EPA regulations. Try drilling the main jet a little bit bigger with a number drill, find a size that just fits and go 1 or 2 sizes bigger until it runs better. Many Zeniths can be retrofitted with an adjustable needle in place of the main jet access plug, that allows you to go a little larger than really needed and lean it back with the needle, to get the mixture precise. I do that with all of the Zenith Carburetors I work on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alRCRVRP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 8:19am
And thank you for that reply. It does have the fixed jet. I decided yesterday to rebuild the carb since it probably has not been for 50? years. And it does almost seem to have the symptoms of a soggy or leaky float.  I'll include changing to the adjustable jet.  Do you recommend an online store that has good kits at a reasonable price.
This page was generated in 0.271 seconds.
