D-12 pros and cons
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-12 pros and cons
    Posted: 28 Oct 2010 at 6:35am
Been mulling over buying a D-12 and would appreciate your comments on this one. Looks original, series 2,says it runs great(only one fuzzzy picture...). I have 2 D-14s but would like a '3 pointed' tractor to use a 5'rototiller... Guy wants $3500 firm,but it comes with 2 bottom plow and rear blade(don't need them though...)
Thanks for all thoughts.
Jay
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 6:49am
You  need range transmission, the hitch to me is not a real strong one. They say that the snap cop. is  a stronger hitch , but the whole lift arms set up to me is weak. I can talk about these tractors because I have a 10 and a 12.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 7:19am
For cons I was going to say that a D-14 is same size and a lot more tractor for (usually) a lot less money but I see you have two of them now, LOL.  If the blade and plow are Allis and decent you should be able to get $7-800 back, there arent many 2 bottom A-C plows w/3 point hitch around.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 8:24am
First won't be slow enough for a rototiller.
If it had the Range then it would be.
Charlie
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 8:33am
The D12 is a powerful little brute; basically the same engine as the D14. However, it's use is limited in that it does not have a power director like the D14. Agree with the others, don't think the D12 is a good choice for roto-tilling. Unless it is the later model with the live pto, I don't think it is a good choice for other pto drive implements. Have used my D12 to pull a 2X16 three point Dearborn plow, heavy 6' disk, 6' backblade, and 2 row corn planter and it has done great.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:10am
I agree with the comments. If you want a good working 3 pt tractor, you could look at picking up a complete 3 pt hitch assembly from a D-15 and installing it on one of your D-14. It would be a unique D-14!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:23am
Hay guys...thanks for the comments..looks like I'm best to buy/make a 3 point adapter for my D-14 and save a few coins. The 'bank' will be happy about that !!
Cheers
Jay
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:31am
Good raking and auger tractors for up to 8in augers a 10 in pushes it though.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 3:32pm
Ford three point arms really beef up those three point hitches and they are close to the right size and length. I like the live hydraulics on my neighbors d-12. You have much better control of your implements  and they work better with modern rams. His tractor is a series three with the range trans.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 5:17pm
D10 and D12 steering linkage and lift setup always looked a bit light to me but they probably worked just fine.  Similar to a CA.   I have heard that without range transmission you will want more gear choices.  I know the Japanese tractors that were matched to roto tillers had real low low gears for that purpose.
