1400 field cultivator |
Post Reply |
timmiso
Bronze Level Joined: 11 Apr 2016 Location: iowa Points: 35 |
Posted: 11 Mar 2024 at 9:27am |
I’ve had a 1400 “chiselvator” for a number of years. I’ve always had problems with the residue bunching in the 3 bar coil tine harrow. Tried numerous adjustments, only way it really works in corn stalk residue (spring tillage after fall disc chisel) is if the harrow JUST touches- so I still have main shank unevenness. My current harrow times measure 12 inches, how far are they worn? Agco still sells them, but at $50/piece I’d have more in it than the unit is worth. Couple aftermarket suppliers have ones that look like they’d work, and that gains me about 3 inches- will that help my clearance problems, or is it just old enough that it can’t flow modern residue. Usually following 65-70 bpa beans (behind r52) 240 bu corn (non chopping head).
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4462 |
Different brand of cultivator, having the same problem. Installer taller spikes did nothing to help plugging. Took me years, but finally took the push down springs off the harrow. Much improvement. Enough weight in the harrow to do a good job. But bounces much more letting trash work through without plugging. But I did not have corn stalks, so your results may vary. But real cheap to try.
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 957 |
How about buying a rough cut mower and mulch the residue into smaller bits beforehand?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
BillinAlberta
Silver Level Joined: 12 Sep 2009 Location: Saskatchewan Points: 338 |
That was my solution until I got a disc. They don't plug.
EarlZamora
Bronze Level Joined: 17 Dec 2022 Location: USA Points: 2 |
All good now?
Post Reply | |
