7060 Power Director Removal
Mdbernau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdbernau Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Power Director Removal
    Posted: 07 Mar 2024 at 8:18pm
New guy here….I’ve got my 7060 split in half and am having trouble removing the power director unit. I have all the bolts out and it is stuck. I don’t have the removal tool but I rigged up a chain on the 2 half inbolts and have it attached to a hoist, but I’m almost picking the rear half of the tractor up and it will not budge, rotate, nothing. Has anyone else had similar trouble and what could I do to break it loose? Thanks in advance for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 10:25pm
Never had the problems you are having. Maybe attach a big slide hammer to one of those 1/2" bolts and give it a lick or three.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdbernau Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2024 at 7:42am
Thanks for the reply Doc. I got it out. It was just stuck, I guess by the o-ring which btw is hard as a rock. Pretty sure this is a survivor that has either never been apart or was a long time ago. I had to wedge a 2x6 between the snout of the power director housing and the case (it fit almost perfectly) and gently pry against the transmission housing and it finally popped loose.
This page was generated in 0.048 seconds.
