Cracked D17 Oil Bath Air Filter Housing
Hayseed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hayseed Quote  Post ReplyReply Direct Link To This Post Topic: Cracked D17 Oil Bath Air Filter Housing
    Posted: 06 Mar 2024 at 7:27pm
Discovered these cracks in the oil bath air cleaner housing on my D17.  Crack starts on one side of the mounting bracket, goes behind the bracket and comes out the other side.  Makes it hard to effectively repair the cracks.  Anyone else ever run across this?
Does the location of the cracks allow unfiltered air into the engine or is the air still going through the oily steel wool part and being cleaned?
1947 All Crop 60 combine, 1955 WD-45, 1959 D-17, 1965 190XT gas, 1968 190XT diesel, 1982 8050, 2000 Monoframe plow and 19?? forklift
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2024 at 7:39pm
Air leaking thru the crack is not pulling the oil up into the steel mesh strainer. Air is entering the SIDE of the strainer and your probably getting a percentage of "cleaning"... possibly not 100%... but some.. Depends on where the cracks are at.. Your at the BOTTOM and a long way from the OUTLET .. that  helps.
Edited by steve(ill) - 06 Mar 2024 at 7:41pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2024 at 8:23pm
just weld it up the one on my wd 45 looked just like that its been welded and sealed back up for fifteen years  you can re move the mesh and clean it and put it back
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 6:23am
Just find a used one. I have some for sale
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hayseed Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2024 at 9:30am
PM sent!
