D12 Allis hydraulic pump |
Post Reply |
Showboat six
Bronze Level Joined: 28 Feb 2024 Location: Oregon Points: 3 |
Posted: 28 Feb 2024 at 10:17pm |
I am working on a 1961 Allis D12 with the PTO hydraulic pump and I cannot get it to make any pressure. I have bled quart and a half of oil out of the hydraulic ram hose but I cannot get it to pump any kind of pressure. Any ideas??
This is the first running of a restoration and I have no information on whether the pump ever worked before the restoration was started. Any information would be greatly appreciated. Showboat Edited by Showboat six - 28 Feb 2024 at 10:17pm |
only AC orange
Silver Level Access Joined: 06 Dec 2014 Location: Eastern Indiana Points: 465 |
Possibly the traction booster is stuck not permitting oil to flow?
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20487 |
Is this a "gear" type pump??? or one similar to a model "CA" or "WD" tractor ??
Macon Rounds
Orange Level Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2143 |
I had one of those pumps that was worn badly and it pumped the oil past its drive shaft back into rear housing of the tractor.
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
If its the gear pump on rear of housing ,check pressure with a flowmeter directly off pump this tells u what pump is doing before relief valve .If its this pump make sure suction screen is clean on pick up tube.
Edited by Fred in Pa - 29 Feb 2024 at 8:04am |
Showboat six
It’s the 4 plunger pump, is there any special priming process for them?
I get a slow oil flow out of the ramp hose when loosened, but no high pressure. |
DrAllis
Fill compartment with oil---self priming. Screw "D" must be clear OUT.
Post Reply | |
