Part numbers
ForeverHomestead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Topic: Part numbers
    Posted: 26 Feb 2024 at 9:52am
I am looking for part numbers for d14 rear axle seals and possible bearings as well.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 3:59pm
#1 70232186 SEAL PINION SHAFT INNER, #4 70206786 PINION SHAFT INNER, # 5  70209890 CUP PINION SHAFT INNER, #6 70227520 CONE BEARING INNER, #12 70230068 CUP PINION SHAFT OUTER, #13 70228509 CONE BEARING PINION SHAFT OUTER, #16 70218284 SEAL REAR AXLE, #17 70218285 CONE BEARING OUTSIDE REAR AXLE OUTSIDE, #18 70210241 CUP OUTSIDE REAR AXLE, #26 70209890 CUP INNER REAR AXLE, #27 70209889 CONE BEARING INNER REAR AXLE. NUMBERS 1&2 ARE SUPERSEDE.
Edited by Kenny L. - 26 Feb 2024 at 4:34pm
This page was generated in 0.042 seconds.
