What adapter is this?
Amac67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amac67 Quote  Post ReplyReply Direct Link To This Post Topic: What adapter is this?
    Posted: 25 Feb 2024 at 9:34pm
I picked this up at an auction with some other stuff awhile back. Best I can tell, it’s a 3 point adapter. Does anyone have any specific info on what it is or what it fits? I’m new to the hobby,any and all info is great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:21pm
It’s not a 3pt adapter. Pieces of a snap coupler hitch. I don’t think that’s how the lift links would be attached. Maybe pieces of a cultivator
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:35pm
Ii think if you had a 3 point implement  ( plow / blade) and you bolted this to it.... You might be able to mount it to the ALLIS bail hitch system ?? ............ it appears the bracket that mounted to the TOP LINK of the 3 points is cut off ?
Edited by steve(ill) - 25 Feb 2024 at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:48pm
maybe similar to this ?? ... but the above is a FIXED attachment for 1 impllement ?... not to be moved between implements.
Edited by steve(ill) - 25 Feb 2024 at 10:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 4:04am
It appears to be the bottom link to a plow or bush hog, that has had some booger weld surgery...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 2:22pm
My rear mnt cultivator has similar hitch...the ball on the left is sandwiched between two metal bars which does the lifting allowing it to sway. A ball on each lift rod. This is a modified something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amac67 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 7:23pm
That is closest thing I’ve seen to what I’ve got here. She’s definitely been heavily modified to suit someone’s specific needs. Missing some pieces too for sure…It’s hard to see but ahead of the top links on both arms are drilled holes (appear to be factory) where that top adjustment is at. Great picture of that attachment, thanks.
Edit, this was supposed to be a reply to Steve but I’m learning this forum business..bare with me
Edited by Amac67 - 26 Feb 2024 at 7:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amac67 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 7:25pm
I’d be curious to see a picture of your setup if it wasn’t much trouble.
This page was generated in 0.056 seconds.
