1992 chevy electronic ignition
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: 1992 chevy electronic ignition
    Posted: 25 Feb 2024 at 4:08pm
Do you guys have a way to check the pickup coil in the distributor other then using a scope? I've got a crank no start pickup with the 5.7. I'm down to the pickup coil or the ignition module. Took the cap off the distributor and everything is very rusty. I'm certain the ignition module bolts will break off of I decide to change that.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 8:10pm
do you have spark ? better put it on tdc and see where your rotor is i will bet if it is the original distributer that the gear is toast and maybe the pin sheared   claen athe grounds and electral plugs, conections
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 9:24pm
Just put a reman dist in. It will be easier and faster than attempting to repair yours. Should come with module and pickup coil reluctor ring assy.
Edited by im4racin - 25 Feb 2024 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 4:50am
Yes exactly like that Steve.
Any time I get a crank no start my first step is give it a small sniff of alternative fuel (don't be a bone head with it) and that will tell me what I'm short. Spark air or fuel. I do not have spark. I even have a extra coil laying around that I use for quick test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 7:32am
real common for the wires to the pickup coil to fatigue and break internally . With 170,000 miles on my one 5.7 GM went through 2 pickup coils from broken lead .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 7:57am
So I got it fixed. I ended up deciding on a ignition module. Once I took the cap off yesterday it was obvious that the customer should have a cap and rotor also. They looked horrible. I called for those. Well after some visiting with the parts guy it was about 25 dollars more to get a complete distributor.
So I'm not sure what was bad seeing as I ended up replacing the complete unit. But it did run again.
On a different note I ended up with a new tool. I. Ground the gear off the old one so I could turn the oil pump as it must have moved when I pulled the distributor.
Also I learned you should always point the rotor at the firewall straight on .
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 5:56pm
Point the rotor to number 1 plug. As you pull it out watch which way the rotor turns and put it back starting the rotor in the same spot. Yes you usually have to line the pump up. I just look down in the hole and align with a long flat screwdriver. Then start and time it.  Some of the late eighties ones you had to unhook the tan wire under the heater fan in cab to time. Not sure on yours tho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 6:47pm
Yes there is a single connector in that area that needs to be unhooked. Then turn dist to 0* advance on damper.  Shut off and reconnect connector. That’s all!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2024 at 7:21am
For what it's worth, that particular distributor (two oval connectors) is referred to as the Delco 'HEI-EST'.  The coil and trigger module operate in a stand-alone state with just power and coil... about the closest you can get in simplicity to a breaker-point distributor, but with the added feature that it requires no mechanical spark advance mechanism, the module does it all.  There's several different modules available, which have slightly different ignition curves, and there's 4, 6, and 8 cylinder caps and reluctors available.  For an odd-fire V6, one can use an 8cyl reluctor and cut two wings off.
They were all set up to work with the 'square brick' type ignition coil, and they threw a scary-nasty snappy-hot spark.
From the factory, they're naturally explosion-proof, so they're ready for the marine environment with no modification... as a result, they were very popular for converting GM Marine 4, 6, and V8's to electronic.
The secondary connector (4 wire) is used where computer 'adjustment' of the spark was done.  With a connector attached, the distributor would respond to computer suggestion and knock sensor(s) to alter the default advance curve, but with the 4 wire disconnected, the distributor would follow it's internally based default advance curve.
Great little distributor, and it did not suffer from the earlier (coil-in-cap) advance mechanism or spark scatter issues.  Bushings lasted really well, and once sealed, they'd stay clean inside just so long as you didn't drive the engine in short-distance cycles and wind up with a plugged up PCV system.  When the engine doesn't get fully warmed up, condensation in the crankcase accumulates, and it gets everywhere (not just in the distributor).  Corrosion inside that distributor is basically always from the engine spending too much time in a 'cold running' state, and not enough 'warm running'.
This page was generated in 0.422 seconds.
