Head gasket with separate fire rings D17 diesel
je1127 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote je1127 Quote  Post ReplyReply Direct Link To This Post Topic: Head gasket with separate fire rings D17 diesel
    Posted: 22 Feb 2024 at 6:46pm
Found a gasket today from old dealer but fire rings are separate. D262 diesel series IV. Any input to install with separate rings?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2024 at 8:13am
Just install - BUT- HOWEVER- WARNING - before you do, check for sleeve stand out. The edges of the sleeves must be a few thousanths above the edges of the block irregardless of what the service manual states. We have done a few that were flush.  IF the sleeve's edge is below the deck you will be doing it again.  Also bottom tap the head bolt female threads in the block - install head bolts w/o washers as 'test' to make sure the bolts will torque the head and not torque because they bottom out. Then replace the head bolt washers of course. Make sure the deck is level and the head flat. Retorque after warming up to operating  temp and reset valves- D262's were not friendly to head gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2024 at 8:16am
also in the "old days' there were head gaskets for Gas, LP and Diesel... as to OEM... the difference was thickness.  The 262 was one of the sweetest running engines around - the sound from mechanics and parts persons were not so sweet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 8:46pm
Finally got it to laod..
Edited by tbran - 25 Feb 2024 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 6:18am
Not sure what a single front wheel weigh's but with the snap-coupler bell spring underneath was this about 6,000 pounds ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 7:31pm
We atcually made it in the 5000# classes. Some scales required the removal of front wt brkt.   Could not do it today the driver weighs 150 more pounds :-)   Almost no oil in tranny, no rear lift housing. Cotton picker tractor.
This page was generated in 0.097 seconds.
