WD45
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 21 Feb 2024 at 6:10pm
  What was the shipping weight of a WD45  with 12x28 rear tires  with out fluid in them?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 6:19pm
tractordata says 3995 gas 4285 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 9:37pm
My WD45 gas with 14.9 x 28's dry and WFront weighs 3600 lbs with 2 gallons of gas in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 10:34pm
Are you buying a trailer Jim?  Or trying to collect on a bet?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 8:43pm
Couldn't get mine under 4300 no weight but I do have a 3pt hitch. Don't think it weighs 700# though.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 9:16pm
Don't know what to tell you. I've tractor pulled mine in 4,000 lbs several times over the years with 200 lbs of me and two 90 lb weights and made the 4K weight class.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 9:26pm
Interesting. Norm's book lists WD45-1953 year- as 3955 from Nebraska test 499. I may have to put mine on the scales here and see what it is. They list ballasted weight as 8005 lbs for the same gas tractor. Man they sure pounded the weight to it!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:27am
Mine is a 1957 build and the rear tires are BKT's which may be lighter than old school rubber.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 5:25am
My 53 NFE scales out pretty similar to the Doctor's. Pulled it in 4000 many times with 16.9x28 Firestone Field and road, weight bracket on the front and one suitcase weight. Probably had a fairly full fuel tank too.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 6:22am
Maybe some liquid ballast in the tires?
I used to get mine in the 3500 lb. class, with no PTO shaft, rock shaft, hydraulic cylinders or rear platform and a narrow front end. They did allow us 100 lbs. over (3600 lbs.).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 7:30am
Shipping weight is listed as 4465 lbs so I guess they left the factory with loaded tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 8:10am
Factory filled, YES......Nebraska Test bare weight included a DRIVER. So, if you take 3955 lbs minus 200 lbs that is 3755 total weight. I'd imagine the fuel tank was full of fuel for another 105 lbs lowering the weight to 3650 lbs bare weight with NFront.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 9:00am
WF, no ballast. Tires were tubed and had been off the year before for new tubes. 10 ply tires so they were heavy, but without dropping the 3pt I couldn't make 4000lb. Ended up pulling 4500lb open class and took second.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 9:08am
that makes a little more sense DR, 3955 with me on it, plus around 250 lbs of aftermarket 3pt hitch would get me where I was scaling. I think the lowest I was able to get it was 4250 with me in the seat. If I dropped the 3pt I would have made the 4000# class by a hens hair.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:22pm
So as you can see I had not enough to do today. So I washed a few vehicles and then scaled the WD45. Lol. So 1954 WD45. All stock except rear tires and rims. I have 13” rims and 14.9 x 28 Firestones. About 1/2 tank of fuel and factory drawbar in place. 3651 lbs is first pic total weight. Next pic just shows the setup. Last pic is with a driver on board but not me! I’m not that heavy(300 lbs as you can see). For a total of 3943 lbs. Time well wasted. Smile  So anyone that was betting against Doc you can send him your money now!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 4:58pm
My 12 volt battery is probably a few pounds lighter than an old school 6 volt and my toolbox is always empty when I go pulling!! Thank you for the "weigh-in" numbers !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 5:31pm
Glad to do it!!!  I was very curious. And yes mine is 6 volt still.   SmileSmile
