Battery Question
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Battery Question
    Posted: 21 Feb 2024 at 3:05pm
Not Allis, but can't find good information so thought I'd ask here.  Need a new battery for my 350 Honda Rancher ATV.  Old battery says GTX14-BS.  Looking online, don't find that one, but see them that say YTX14-BS.  Any idea what these letters/numbers mean or indicate?  Will the YTX14-BS work rather than the GTX14-BS.  Quite a difference in price for one on Amazon compared with the local Bomgaars, so wonder if I can go with the YTX one.  Any suggestions would be appreciated.  Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 4:01pm
Different manufacturer... basically the same physical size battery and interchangeable on ATVS.. I think the Y is a 240 CCA battery and the G is a 200..
Edited by steve(ill) - 21 Feb 2024 at 4:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 4:07pm
What does YTX mean on a battery?
References starting with these prefixes are Maintenance-free AGM batteries. The first letter generally identifies the manufacturer (Y = Yuasa, E= Exide, F= Fiamm ou Fulbat…). E.g. Meaning of the battery number “YTX7L-BS”: "YT": Manufacturer reference. "X": High performance battery.
Edited by steve(ill) - 21 Feb 2024 at 4:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 8:07am
Thanks, Steve.  That kinda helps to understand.  I found this one on Amazon and it says it will work for the Honda Rancher I have.  Any idea if it would be good?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 8:11am
ii normally look for the "4 star rating".... That battery has 1000 customer comments and 85% are 4 or 5 star..... That should give you some confidence..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 9:35am
Just know there is big price difference between AGM and lead acid but the AGM is a better buy.
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 7:48pm
Is the AGM a better buy because it will have a longer life? Just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2024 at 8:55am
AGM batteries are called "sealed and maintenance free"... as compared to the old standard batteries that you added water to the "lead -acid" thru the removable caps. In theory the AGM batteries last 6-8 years and the Lead -acid last 3-5 years... Of course a lot of that depends on how you maintain them , proper charge , winter storage, etc...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2024 at 9:49am
Well, I went ahead and ordered the battery I put the link for.  I'll keep you posted on how things turn out.  Thanks for all of the assistance.  Dave
This page was generated in 0.046 seconds.
