PTO Seal
ForeverHomestead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Topic: PTO Seal
    Posted: 17 Feb 2024 at 2:31pm
I am rebuilding my D14 and while painting the transmission housing I see there is an oil seal in the front where the PTO shaft runs through to the torque housing. Both of these housing share the same hydrolic fluids for as long as I have had the tractor. My question is should I replace this seal and change the fluids back to transmission fluid in the transmission and hydrolic in the torque housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 3:06pm
both compartments can run universal trans/hyd fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 3:45pm
So really no need to replace that seal?
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 6:00pm
There's three compartments on a D14, hydraulic up front, power director in the middle and transmission/rearend. Is the tractor split now? The fluids levels are different between the compartments I believe.
Edited by Gary(VA) - 17 Feb 2024 at 6:03pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 9:41am
They run the same fluid, but they are at different levels.  If it is already apart, replace the seals on the PTO shaft and the transmission input shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 12:58pm
Best answer is fix seals and fill compartments to proper levels. One and done but not the easiest. You have to decide if u want it fixed or patched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ForeverHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2024 at 4:07pm
Thanks guys.  That all makes sense.  It is apart and now is the time.  I have a few months into the project now.  So what is pone more order for seal going to hurt. lol
I did think if there is a seal there must be a reason.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2024 at 4:40pm
Yes , if it has not been apart before you may find some old leather seals in the middle bottom where the back to back 70227679 seals are located. 70241779 is the rear seal and check the splines on the front of the PTO shaft for burrs. The trans input shaft seal is a pair of 70235847's and you should be all sealed up.
