Anti Fog Full Face Shield,,,,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Anti Fog Full Face Shield,,,,,??
    Posted: 11 Feb 2024 at 2:37pm
 Howdy,,,I was cruising thru MarketPlace and seen a new style face shield that is ANTI FOG.
   I had bought a face shield at welding supply store and first rattle out of the box,,,the frigging  face shield developed a scratch dang near all the way across,,,mind you right at eye level TOO,,!!!It now has so many scratches is almost unuseable,,,,
 The one on MarketPlace looks like the right idea,,, and has a ONE PIECE Rubber SEAL at chin level and around your ears and at the eyebrow level,,and all One piece,,!!
 Has anyone seen these face shields and used them? Since I wear glasses, I have a reall issue with fogging up with any face shield and wind up not using one and that is even worst,,,???
 Anyone else seen these,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 4:07pm
I buy inexpensive throw aways as all will eventually scratch to a haze, worst is forget NOT to use Paper Towels on them and scratch even worse.  Use polishing style cloths, wet or dry, only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 4:45pm
Joe, i have the same problem and i wear glasses also.. I ended up getting a PACK of face shields.. Maybe 5-6 in a box.. Its a hard flexible plastic maybe  10 inches wide and 12 inches tall and wraps around your face. has a head band to hold it on.. Not a real seal on the sided and chin, but thats what i needed.. Let it breath and still lots of protection from the front and some side..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 4:50pm
something like this... BUTT, BUTT... the girl dont come with it !! (dang)
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 6:15pm
 Dang it,,I shoulda got a pic of the model they listed. I use LOTS of the 4 1/2" grinder discs and was looking for some side eye protection from the tiny metal cuttings,,,,and maybe some protection from a grinding disc disentegration,,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 6:39pm
they gots some that got more "seal" to them... but i still have problems with the FOGGING... I use the el-cheapo shown above.. just keep the grindings away from my face.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 6:56pm
 You are TOO dang quick,,,Steve,,I fount these on Amazon as well as Walmart, but the walmart delivery is way too long,,
 SO, these still fog up,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 8:14pm
i have not tried that specific model.. Just saying "in General" i have fogging when i put on a face mask or even vented Goggles... I have to use something that is open on the back of sides and bottom to get some air flow... I try real hard to SHOOT the grinding specs away from me or at the ground.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2024 at 7:38pm
i have never seen any anti fog anything not fog up the same as every thing ealse maybe somthings stays clear afew minets longer when they are brand new and have never been cleaned
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2024 at 11:07am
Might look at some of the anti-fog spray used for Motorcycle bubble helmets and goggles . Seems there are several different ones on the market .
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2024 at 8:51am
