6to12 conversion
mhbier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Topic: 6to12 conversion
    Posted: 10 Feb 2024 at 5:37pm
Any suggestions about converting my D14 AC from 6 to 12? What kind of alternator, what kind of coil etc.? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 6:22pm
any alternator with an INTERNAL VOLTAGE REGULATOR would be fine.. The "old reliable" was the DELCO 10SI ...... The last 10 years many people have started using the SMALLER DELCO CS130 , or the DENSO mini alternators. The wiring is similar for all. Tell us which one you get and we can post a wire diagram.. ... Coil is not a big deal.. Just get a 12 volt ( with internal resistor) at the local Auto store or Amazon, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 6:24pm
This is a common alternator to use... the "three wire" is a better choice than the "one wire"..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 7:37pm
something like this.......
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 8:16pm
No alternator required. You can get the generator rebuilt and wired for 12 volt. Get a 12 volt voltage regulator, coil and points for 12 volt system. Done deal.
Did it to my 58 D14. Works perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 8:38pm
You can get the generator rebuilt and wired for 12 volt. Get a 12 volt voltage regulator..............
..what did that cost ?
Edited by steve(ill) - 10 Feb 2024 at 8:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 9:02pm
I think it was around $150 a few years ago. But no mods required trying to make an alternator fit.
I have a bit of a pet peeve seeing modern alternators on classic tractors too. It's a cheap price to pay to maintain the tractor's originality.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 9:35pm
I like that idea Myron. Nice to keep the original look. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2024 at 12:05am
Everybody has their own opinion about how they want to set their Tractor up. When it comes down to it, going with an Alternator is the cheaper way to convert. I've converted a lot of 6V Gennies to 12,  with mated VR's, as well as the Starter motors. Completely up to the individual. It is more expensive having the OEM components changed over, but again, like I said, it's up to the individual. We offer a 12V conversion for the "D" series Tractors in kit form with different options. If you visit our website, you can see what we offer. We specialize in electrical, but we touch a little on each category of the Tractor.  ie-engine, drivetrain, fuel system etc.
Steve@B&B
bb-customcircuits.com
