Allis Chalmers B Plug wire
kearly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kearly Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B Plug wire
    Posted: 09 Feb 2024 at 8:59pm
My "new" B runs very rough.  I will change the plugs but wonder if the plug wires are going to the correct plug.  Anyone have a diagram?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 4:38am
1243 clockwise from above...
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 9:50am
Plugs and wires are only half of the ignition system.  Might not solve your problem.  Might as well replace distributor cap, rotor, points and condenser at the same time.
Rough running can also be a fuel issue.  Also recommend getting your carb cleaned/rebuilt, as well as cleaning out the gas tank and putting a new screen in the sediment bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 3:13pm
A rough running engine could mean anything from needing a full tune-up to a tight or bad valve. If it happens to have Champion plugs in it, that could be your problem. Take them out and throw em' away and put a real set of sparklers in there like Autolites, AC's or NGK's. Autolite 295's can be used with worn engines. Autolite 303's can be used with a new rebuilt engine. If Magneto equipped, use solid core wires with 295 Autolites. If you need any tune-up parts or wires, visit our website. We can help ya out.....
Steve@B&B
bb-customcircuits.com
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 6:38pm
#1 is front by the radiator.... wire on Mag is at 11 o'clock ......#2 is at 2 o'clock ....#4 is at 5 o'clock .... #3 is at 8 o'clock ......... 1 - 2 - 4 -3
photo-----
Edited by steve(ill) - 10 Feb 2024 at 6:39pm
