d14 compression
mhbier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Topic: d14 compression
    Posted: 08 Feb 2024 at 3:21pm
I bought a used D14 and would like to know the normal compression.  Presently it is 115, 100, 100, 115.  Is the normal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 3:35pm
All compression tests need to be done with a battery charger on the battery, all spark plugs removed and the throttle WIDE OPEN. Looks a little low to me ( 135 psi new engine spec) but you're opening a can of worms to improve it. If it runs fine and doesn't smoke BLUE when warmed up, leave it alone.
Edited by DrAllis - 08 Feb 2024 at 4:03pm
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 4:01pm
Not sure if my gas D 15 is exactly the same , but my comp was around 140 PSI average when last I checked . Have had my head rebuilt . HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 4:34pm
D-15 series 1 are 160 psi new engine spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 5:40pm
According to the I&T manual, 135# at cranking speed.
While 2&3 are  a little lower than 1&4, it's probably just fine for a 70 year old...
Meanwhile there's other things you can open your wallet for.....
brakes, PTO O ring, 3rd gear, oil leaks, rear rubber,.......
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 7:34pm
I would need more reasons than that to justify tearing it down. As Dr. Allis said, excessive blue smoke AFTER fully warmed up, massive oil consumption, coolant loss, hard starting etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 11:51am
Thanks for your responses re: my d14.  I am waiting for my manual in the mail. The rubber appears to be almost new.  The tin has some high-altitude sunburn but otherwise is in great shape. The front end is very firm and solid. It looks like it was cared for in its earlier life and been sitting outside for some time in its later life.  But for $1700. it looks like a good project.  I haven't had an opportunity to really work the transmission, but it appears good. The only question is the power director. It seems to go into low alright but doesn't want to stay in high range. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2024 at 11:55am
Start by removing the lever stop bolt for a test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 10:32am
moving the lever stop bolt took care of the problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 1:50pm
Now, remove just enough flat washers to achieve the same thing. Technically, the stop bolt should be there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhbier Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 2:18pm
Thanks, I did just that
This page was generated in 0.037 seconds.
