WD/WD-45 Wheel Wrench |
| Author | ||
Brian G. NY
Topic: WD/WD-45 Wheel WrenchPosted: 06 Feb 2024 at 2:00pm |
I have had this wheel wrench for many years and have never used it. I never did have the handle (#3). It looks easy enough to make....can someone give me the length?
A young friend of mine is restoring his Grandpa's WD and I'd like to give it to him to display with his tractor at shows. ![]() ![]() Edited by Brian G. NY - 06 Feb 2024 at 3:19pm |
| Sponsored Links | ||
Ken McGregor
Joined: 11 Sep 2009 Location: Strathroy, Ont Points: 142 |
Posted: 06 Feb 2024 at 2:20pm |
What is the purpose of Item #6 in your diagram? I don't recall usung the grease gun for anything other than the water pump fitting. There is a special grease used for that. The spatk plug wrench was probably the most used item in the tool kit. regards, Ken McGregor
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 06 Feb 2024 at 2:35pm |
That wheel wrench was for the power adjust rear wheels on the WD/WD45 would also work on D14/15/early 17. There probably is much on a WC that it will fit.
Brian G. NY
Posted: 06 Feb 2024 at 2:45pm |
I have never seen one of these....I cross referenced it in the parts manual to show how it was used. Item 11 on this page.
![]() ounted. |
Brian G. NY
Posted: 06 Feb 2024 at 3:02pm |
A-C refers to it as "WRENCH, Front and rear wheel bolts". I believe it fits the rear adjusting cam (eccentric) bolts as well as the lug bolts. Fat chance it would ever turn a well rusted cam bolt. LOL
Edited by Brian G. NY - 06 Feb 2024 at 3:05pm |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3980 |
Posted: 06 Feb 2024 at 3:23pm |
Brian. Here is the set from my D17 (original paint yet!) It also fits my WD and WD45, Handle is about 13 3/4 " long. |
Kenny L.
Posted: 06 Feb 2024 at 4:32pm |
Brian sent you a pm
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 07 Feb 2024 at 6:43am |
I used that handle as a gas gauge.
http://lonsallischalmers.com
Mikez
Posted: 07 Feb 2024 at 7:52am |
Thought they were for both rear wheel spin outs and adjustable front axle. That why original tie rod clamp has the large nut. So that wrench would fit.
What’s nos handle worth
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2164 |
Posted: 07 Feb 2024 at 8:27am |
I have a few of the wheel wrenches and breaker bars for sale:
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4273 |
Posted: 07 Feb 2024 at 8:47am |
Lon, you're not the only one that did that!
Brian G. NY
Posted: 07 Feb 2024 at 9:06am |
Thanks Phil.
I think the WD/WD-45 wrenches were black. I guess they changed the color fot the D-17s. The one I have is N.O.S..
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3131 |
Posted: 07 Feb 2024 at 9:09am |
I'm not sure those would loosen most of my wedges today.
dfwallis
Posted: 07 Feb 2024 at 11:12am |
Looks identical to my CA wrench set (except for the CA square head socket I guess). I don't recall seeing the CA version with noticeable paint. I think it was rusted pretty bad the first time I saw them in the mid 60s. Pretty sure it wasn't orange. I would probably have seen some orange spots at least. They were most likely black. When I found them again last spring though (shocked), I sandblasted and painted them orange so everybody knows they're mine :)
Edited by dfwallis - 07 Feb 2024 at 8:00pm |
1952 CA13092
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 07 Feb 2024 at 1:27pm |
The ones for my CA and D14 are also black.
Brian G. NY
Posted: 07 Feb 2024 at 3:46pm |
Seems I heard that the CA cam bolts had a square head.......might be totally wrong on that.
dfwallis
Posted: 07 Feb 2024 at 4:33pm |
Yes, they are square heads.
1952 CA13092
Dave (NE)
Posted: 07 Feb 2024 at 4:35pm |
yeah, 1/2" square. if you run across one of those wrenches, they are rare. I have one and it is the only one I've ever seen.
Alberta Phil
Posted: 07 Feb 2024 at 7:20pm |
My D 17 came from the original owner near here. It was very well maintained except for the last year when it sat with a bad tire. The original owner may have painted the tools way back when. I just assumed they were originally orange although they could have been black. Only set I've ever seen as my WD's and WD45 had none when I got them! At least these fit all the tractors I use!!
