Two speed for D17
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Topic: Two speed for D17
    Posted: 06 Feb 2024 at 11:03am
I believe it has been done, I would like to convert the power director clutch to a manual shifted two speed without the clutch discs.Any help would be appreciated
Pullin With AC
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 7:46am
My question would be why?
The power director will hold a lot of power and is relatively easy to rebuild. Unless, you are planning very extensive engine modifications, a power director should handle all the power a D-17 engine (gas or diesel) would have.
When pulling, you can leave it in either high or low, which you would have to do with a mechanical two speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 6:56pm
Extensive engine mods, I'm no sure the clutch package will hold
Pullin With AC
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2024 at 1:14pm
We pulled a D17 diesel IN THE '70'S - two turbos - always started the sled with hand clutch running ATF - bolted up the foot clutch. 7th gear in 5000 class. Unless you are turning over 4000 rpm the PD clutch will not be an issue. Just as with cast iron flywheels - the clutch is cast iron as well. If still have doubt - find a D19 unit - it has 5 plates in the low side 4 high.  (and no we could not keep the head gasket sealed  )
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2024 at 8:22pm
Boy Tim!  You guys had some wild hair days back when.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 1:10pm
I have a picture on home computer - will try to post.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 9:45pm
Put a D19 PD in it !!!
Been there done that !!!
It is EXACTLY the same design. Just has more clutches.
And you wont loose the ability to shift on the fly.
