Tachometor Allis 185
Eslinger Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eslinger Farm Quote  Post ReplyReply Direct Link To This Post Topic: Tachometor Allis 185
    Posted: 03 Feb 2024 at 7:25am
I am having trouble finding the correct Tach for My Allis Chalmers 185, I have purchased 2 tachs and both read RPM slow. Serial number 13991 all original, I am replacing the original tach because the hour meter is not working but the rpm works just fine, has good cable, has 12 and 45 gears, has original alternator and drive, has 4 inch pulley, my guess is that they made 2 different tachs for this tractor and have superseded to one tach now
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 7:42am
There are people around this great country of ours that REPAIR those tachometers. FIX YOURS. The one guy my brother has used is in Florida. Star Speedometer 386-569-5284
Edited by DrAllis - 03 Feb 2024 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 7:56am
Welcome to forum.
Like dr said above. Maybe the other guys will chime in with you they all use
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 7:58am
...and there are also a lot of aftermarket companies importing poor quality gauges and tachometers and selling them as original equipment replacements.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 11:53am
I will vouch for Star Speedometer!
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 5:56pm
I totally support sending your factory Tach to one of the recommended service shops for a repair/cleanup and you will end up with the best possible outcome, factory quality and appearance
My 1963 D17 Diesel Tach stopped working and the face plate had a bit of a sunburn. I was able to carefully open up the Tach case using curved needle nose pliers and a flat head screwdriver. Extreme care and patience needed to avoid spoiling the metal and glass. The needle pulls off upwards gently
Once I had it apart carefully cleaning of the moving parts, oiling of the gears etc and had it working smoothly ready for another 60 years. Cleaned the face plate with water wet Q tip several times and it looked okay
Reassemble carefully using the screwdriver and pliers   Can hardly see the repair marks / scars. NOT Show quality but operating just fine. Time invested 4 hours Cost sore fingers
I was happy with the results and I enjoy this type of project
My father/brothers who still farm would have sent the Tach to the Pro’s in a heart beat
Hope this posting helps others with options available
PS Internet/YouTube examples mostly vintage cars/boats
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 3:08am
I plan on calling them Monday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 11:46am
I never worried about the rpm,s- just crank it up and listen to the machine- you,ll know when its right
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 7:06pm
Don’t waste your money on aftermarket tachs. Send it to Star Speedometer, he has repaired 3 for me, they look and work like new. Those tachs are precision pieces and Haim will have it back working like it should.
