Jeep charging troubles
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Jeep charging troubles
    Posted: 02 Feb 2024 at 8:30pm
1996 jeep cherokee with the mighty straight 6. Customer said its not charging. Bring it in and confirmed. New alternator check my work looks great ship it out the door. A month later he is back. Now it charges 18 volts. Customer seems concerned.
From the studying jeep decided to hide the regulator in the computer.
I've looked the wiring all over very well. Took the battery temp sensor out of the battery box and warmed it up. Scan tool showed it reacted to temp change. Set the temp sensor off to the side. Still charging 18 volts. Battery tests good both with multi meter and a pile tester. Alternator is a month old.
I'm thinking of condemning the computer. What kind of mess am I looking at there. Oh and where do I find a computer for a nearly 30 year old vehicle. I'm guessing my local napa or orielly won't have one handy.
I'm guessing I'll have to program the computer too... I'm a bit over my wheel house here but I hate to say no and he's a good customer.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2024 at 8:52pm
You are on the correct track with the ECM being the culprit. Your retail auto parts outlets will have them available without much problems. Have the last eight of the VIN with you when ordering.
Chrysler used the ECM to control field excitation in the alternator for a lot of years and this Jeep is included in that scenario.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2024 at 9:55pm
Probably not your problem, but  2 months ago i put a new battery in a 2019 FLEX.. It has a Negative battery clamp and 3 extra small wires like 16 gauge connected to little studs on the BIG CLAMP... I had to take the wires off to get extra movement of the clamp to get the battery out.. TIGHT AREA.... Apparently when i put the 3 little wires back on i forgot to tighten one little nut holding it to the stud... Week later had all kinds of funny electrical problems. Checked charging and i had 15.8 volts  ... ...... Finally found it when i went to pull the battery back out.....
Just saying, a bad GROUND for the ECM / computer could do the same thing. ... or possibly a plug on the alternator / bad ground reference..
Edited by steve(ill) - 02 Feb 2024 at 9:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 1:58pm
ALL manner of Electronics issues with bad or Loose connections.  GREEN Connections at the ECM connector same issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 4:46pm
I'm very hesitant to do the computer. I can't see anything else that's bad though. I wish there was a way I could rule the computer bad for sure.
Possible the new alternator is bad? Could it have grounded it self some how? Any way to tell that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 5:37pm
If i had a 30 year old car with charging problems.. I Would get a SIMPLE alternator with internal regulator and wire it to the battery and let the Alternator figure out when to charge,,, NOT the computer..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 6:30pm
check 'pongo's ' reply 3-4- down...
googled 'jeep alternator 18 volts' to find this....
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 8:00pm
I have an 89 Jeep Comanche pickup with ongoing electrical problems. The problem id with the fuse bock. A couple of the fuses have intermittent terminal connection problems. The fuse for the blower got hot due to poor connection and because of the power load it melted the fuse block in that area. The ignition fuse has intermittent problems which often ends with a dead or weak battery as the battery will stop charging if the fuse loses connection.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 11:54pm
Is the alternator putting out 18 volts, or is the gauge showing 18 volts? Possible faulty gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 2:27pm
Alternator is putting out 18 volts yes. I verified that right away
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2024 at 5:04pm
Seems electrical problems are the new gold mine on repair - the throw parts at a problem until solution is found is Mfg idea of fix .
 Stop / Start light comes on on my 2015 Cherokee at odd times 20 miles of driving 5 miles next time , Light goes out when restarting only to show up again in xx miles .
 Asked dealer about it back when under warranty - said they checked - no problem they could see . Once out or warranty and asked again said $200 to $300 to fix IF it was ?
  Every once in a while if you energize it manually - a notice of LOW battery - charging , low voltage , not in service at present comes up in display .
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 8:37pm
I've had three Cherokee XJs.  Never had a computer be the culprit.
Always had ground wires be the culprit...  Always the ground wires.  Even if they LOOK good, bypass them with a jumper, and when your problem corrects itself, you found the bad wire.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 11:27pm
I've had two with bad ECM's. One in fairness had a charging problem but the a/c clutch was also controlled through the ECM and it too was non functioning unless the computer was bypassed.
Both systems are cut out, or back upon acceleration to lessen parasitic drag on the engine such as for rapid passing another vehicle.
Grounds and their respective terminations cannot be overemphasized or addressed too deeply. They are essential and marginal when the vehicles are built using the smallest gauge wire that will accomplish the task without any degradation which sets in with time and exposure.
That's All Folks!
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2024 at 9:09am
  Interesting, I like to shut AC off for a big pass.
