Allis Chalmers C engine rebuild for grandad
Garthster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C engine rebuild for grandad
    Posted: 29 Jan 2024 at 10:27am
Started rebuilding an allis chalmers C tractor engine for my dad. I have done around 4 allis engine builds so far and this was a great oppertunity to have my son Jack start learning some good hands on skills under my watchfull eye.Jack is currently 12 years old and did really well. Part one is linked below. I will upload more as i get the time to edit.
https://youtu.be/bk3DqlyODgc?si=2GqP49FT-oHTBdUV
Edited by Garthster - 29 Jan 2024 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 12:47pm
Teach them  young... Mechanical background will be a benefit for LIFE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2024 at 10:20am
Part 2! We finish cleaning the block, reface the lifters, install the cam bearings and set the cam.
https://youtu.be/MYGJVmgW1xU?si=q_KtyGNuc7EeqPuo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2024 at 10:13am
Part 3 we manage to get the crank set
https://youtu.be/9os7y90iZBw?si=FuJZwTlA4W2rCQ0v
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2024 at 10:54am
In this episode we prep the head and get the vale guides installed.
We then set up the surface grinder and jack grinds the valves.
https://youtu.be/j-oEjR8q74M?si=JqUZXsmNulfVCn8u
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 11:07am
In this weeks episode we cut the valve seats and install the valves.
https://youtu.be/Ph9Ya5IoIf8?si=28PV8M-WfFazkorH
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2024 at 12:32pm
Great movies... looks like he is really interested and Learning something !!!... PLUS.. you cant beat the time you have spent with  Kids ! ... I spend as much time with my Grand Kids as i can get !
Edited by steve(ill) - 25 Feb 2024 at 10:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2024 at 2:19pm
In this weeks episode win install the new sleevsn rings pistons and bearings.
https://youtu.be/Y9CTansFw7A?si=UU2iGZ993vNC011_
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 6:48pm
In this weeks episode, we get the head installed and make a longblock!
https://youtu.be/rIWLvy6lEyI?si=xVLVyD6uN5BYg5su
Edited by Garthster - 10 Mar 2024 at 6:48pm
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 9:37pm
Awesome vid!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 10:08am
In this weeks episode we fix a broken bolt in the manifold, make a ne rocker arm stud, install the front pulley and insall the rocker.
https://youtu.be/-PD7aXpJBSk?si=dVhfDNWQGl2J6KoR
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garthster Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 12:23pm
In this weeks episode we sort out the carburetor. It was a real pain......and the go pro died at the end and I lost the footage on assembling the carb shafts
https://youtu.be/e5-I8_rX_vc?si=zYDCRhtFAIzJqEaT
