My parts washer.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: My parts washer.
    Posted: 28 Jan 2024 at 6:06am
The hand cleaner post got me thinking on this.
My parts washer is a plastic barrel with a big aluminum tub on top for a basin.
I use an old 12 volt fuel pump powered by an old 12 volt battery charger. I built this contraption in the early 90’s.
The fuel pump has a built in canister filter with a washable filter.
I use mineral spirits for solvent now days.
It’s getting quite expensive to fill it these days.
It will run on anything from 5 gallons to 50 gallons.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 6:36am
Mine is an old "GrayMills" washer. It uses a "Little Giant" explosion proof pump but no filters. It has both the soak capability, and the flexible wand for flooding, or a flow through brush. I've had this since the mid 1970's and it's always worked well. I've always used mineral spirits in it but being covered the evaporation rate is very slow. With the use it gets, (and this is often) I probably lose three gallons per year in both evaporation, and what remains on parts that air, or compressed air dry off. I can heat it but usually do not. I snaked a perforated copper tube through the bottom and a constant flow of air to agitate the solvent quickly aids in degreasing parts. Increasing air pressure increases agitation of course for any submerged parts.
I cannot have greasy parts go through my blast line so this is the treatment they receive first as mineral spirits leaves a very clean finished product.
That's All Folks!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 7:54am
 Hey Thad,,,that right there sounds like a very workable piece of equipment to have,,,Ya know,,as long as I been shade treeing,,I've never used mineral spirits as the cleaning agent,,,maybe one day,,,,??Clap
