Spark plugs
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Topic: Spark plugs
    Posted: 26 Jan 2024 at 12:48pm
I have a WD45 with a D17 head, Series 1 or 2. What spark plugs should I use?  Thanks.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 2:12pm
From the manual:
The early D-17 engines use a 3/8" reach plug eg: A-C 45, Autolite A-7 or Champion J-8.
 Begining with "engine" Ser. #17-17293, a 3/4" reach plug was used eg: A-C 45XL,  Autolite AG-5 or Champion N-8.
I don't know if those plug numbers are still available but can probably be cross-referenced.
You may not know the engine number from which your head came.....in that case, I guess the depth could easily be measured. Or..... someone here may know the head casting numbers.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 2:31pm
3/8" plug heads have smooth cylinder head castings front and back. 3/4" plug heads have a core plug in each end of the head.   Delco R45 plugs for 3/8" reach and R45 XL for 3/4" reach plugs. If the plugs currently used are 3/4" reach and they aren't SMASHED they are correct length.
Edited by DrAllis - 26 Jan 2024 at 2:32pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 2:39pm
Take a plug out, and see what you got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 3:09pm
Thanks. The plugs in it were in it are RN11YC4. Have no idea where I got them or why. Don't know if they have some unique feature.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2024 at 4:40pm
If they are in reasonably good shape just clean and reuse. Don't need anything fancy in those motors. Set the gap as well.
