Another CA Plow Post
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Topic: Another CA Plow Post
    Posted: 25 Oct 2010 at 11:07pm
I didn't want to hijack Brian's post on the his plowing issues so I started another thread.
I'm mostly happy with the way my CA plows but one thing that bugs me is that I can't get a flat bottom furrow. Winging adjustment opened up to almost the last thread won't level it up from the same 30 degrees Brian talked about. Everything else is good. Plow is appears beamed correct and both bottoms turn the dirt nicely. Tractor is exactly as purchased in 52 with same tires and I might be the first person to have used the plow (2-12's) so no wear there. This is a pin hitch.
Also I couldn't be happier with the power of the little CA. It pulls the 2-12s in 3rd easily sometimes loafing along at 3/4 throttle.
