1940 Allis Chalmers b |
Hardwater000
Topic: 1940 Allis Chalmers bPosted: 18 Jan 2024 at 6:47pm |
Restoring a, b tractor have a question about the steering column original has rust holes, was wondering about the square piece welded to the column toward the bottom above the steering box. What is it's purpose? Plan on making my own column and was curious about that piece.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3940 |
Posted: 18 Jan 2024 at 7:27pm |
On the early 'B' tractors, that was where you stored the hand crank. I have a '39, crank start only and all original. I'll see if I can get a picture of it showing the crank in place.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88653 |
Posted: 18 Jan 2024 at 7:50pm |
i dont know if you have measured the tube or not... but it is the same as a steel Conduit.. you can buy a section at the Hard Ware store.
Alberta Phil
Posted: 19 Jan 2024 at 5:48pm |
Here is a picture of the crank in it's storage place on my '39 'B'. |
John426
Posted: 20 Jan 2024 at 3:08am |
Hy
Where is the crank storage place on B or C which have a battery box ?
Hardwater000
Posted: 20 Jan 2024 at 6:17am |
Ok I was starting to worry that maybe I was missing something that it may bolted to, but it doesn't have any holes in it to bolt to anything. Yes I was going to build one out of thicker material I think other than coming up with a type of bushing it Shud work I think.
steve(ill)
Posted: 20 Jan 2024 at 8:11am |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12027 |
Posted: 20 Jan 2024 at 10:23am |
The B's that were equipped with a Battery, the crank was on the shelf in the barn... ![]() Steve@B&B |
