7000 hydraulic pump kit
dp7000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 hydraulic pump kit
    Posted: 17 Jan 2024 at 9:45pm
Hello Big Orange experts. Where’s the best place to get a kit for a black belly 7000 hydraulic pump? I searched archives and didn’t find any recommendations. Thanks much. dp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 10:18pm
I've bought two kits from A & I and was happy with the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 10:31pm
Thanks Doc, exactly what I needed to know. I value your experience and opinions.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 8:24am
We use the A&I kit but if we need individual parts the AGCO old White/Oliver PN#s are still available. 20-7300762  20-7300763 20-7300764   are the outer ring and eyeglass seal both blue and soft black.   24d001 is AI the kit with plates  and 70255947 is the AGCO seal kit w/o the wear plates.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 11:17am
Is the 24d001 the one for the 2 section pumps the 7000's use?  Just verifying because the online retails I have found don't list the 7000 in the application list, but I thought the pump was more or less the same as the 200 pump.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 11:59am
Kit for 180/185 will work extra parts leftover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 2:46pm
Interesting, I think the front seal is out on mine. Was using tractor to unroll hay, backed up to a roll and lift arms wouldn’t raise. Heard a pop but don’t know if it’s related. Was very cold. Steering worked as well as power shift. As I returned to the barn to change tractors lift very slowly came up. I looked in the hydraulic filler tube and saw oil moving with air bubbles. Do you think front seal is all that’s needed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 5:36pm
My experience with the front seal is the pump loses it's prime. If it has blown out I'd expect engine oil level to maybe raise ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2024 at 6:38pm
Engine oil unchanged. I think it’s sucking air. I read on another post there’s an elbow underneath? I haven’t looked into that yet. It’s been too cold. I don’t have a heated shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2024 at 8:44am
If sucking air, check the elbow and also the doughnut gaskets on the suction line at the pan.
Hurst
5800 Hours
