Looking for a part
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a part
    Posted: 16 Jan 2024 at 11:10am
I need a radius rod pivot bolt part # 219900. TIA.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 5:02pm
Photo, illustration or application might help those of us who don't know what that is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 6:46pm
Mounts under the front of the engine cross brace on a WD-45 4 bolt wide front end. It’s a weld on part.
Edited by sparky - 16 Jan 2024 at 6:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 6:59am
Nothing more than a 7/8" square head bolt with a hole drilled through it. Just measure the length of the worn out bolt you now have a replace it.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 8:19am
WD, WD45, WD45D Parts Catalog
219900 - page 250 & 251 - item 37, used on all 3 Models.
G
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 9:36am
While Paul is correct, if you want it to fit you need to machine a radius into the head of the bolt. I did this on my Wide Front 45. I'll ;look and see if I can find the thread and if the pictures are still there.
Edit; No luck finding that picture, found the thread it would have been in but many pictures missing due to the file manager. Can't even find it on the computer???
Found it!
Edited by IBWD MIke - 17 Jan 2024 at 10:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2024 at 8:38pm
Thanks everyone. I found one today from Lon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2024 at 8:18am
Way ta' go Lonn!  The man has the parts!!  Thumbs Up
Steve@B&B
This page was generated in 0.398 seconds.
