160
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Topic: 160
    Posted: 15 Jan 2024 at 2:47pm
I've had a couple of 160s offered to me and through research the only problems that have shown up have been the lift doesn't work. Is this the big drawback on these tractors? One of the tractors does have the lift problem, the other doesn't. The one with the lift problem only has around 500 hrs so I'm guessing it was either abused or neglected. Both run, go, and stop. Haven't seen them up close so I can't speak to actual condition. What are they worth?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 6:35pm
It's been a long time, but my uncle had a 160 that I worked on some.
There is a filter screen (I believe) that is on the left side near the clutch pedal, that has to be kept clean. If the hydraulic pump won't pump. it can sometime be "primed" by taking off the lines and filling it with hydraulic fluid.
The hydraulic pump does seem to be a weak link on the 160, but aftermarket replacement pumps are a lot less expensive than a lot of tractors ( and readily available).
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 9:33pm
WF is exactly  correct - there is also a suction strainer under the seat under a 3 bolt cap - remove it and punch some larger holes in the nylon with a ice pick and it will work better in cold weather - it will probably be covered with milky oil - in that case drain and flush and refil and clean the filters as well.  You can tell if the lift issue is pump or in the rest of the 3 point system by operating the remote lever and listen to see if it 'lugs' the engine - it not then the pump is the issue - or it needs 'bleeding'
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 10:37pm
The only lift problem I have encountered with my 160 is when fluids are changed, filter change, cleaning of the hydraulic suction filter or if the suction coupler joining the 2 pipes together becomes loose sucking air into the system. That happened when I split my tractor to replace the clutches. I forgot to tighten the clamps. With that being said, a simple solution that works for me is to simply connect a 4’ hydraulic hose into the top hydraulic coupling and the other end into a clean container. Make sure the tractor hydraulic fluid is full. Operate the rear remote back and forth clearing any air in the system until a full stream comes out. Move to the second remote and repeat the procedure. Once this is done my hydraulics and lift arms return to operational condition. Refill tractor hydraulic reservoir.
Edited by AC720Man - 15 Jan 2024 at 10:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 12:05am
Thanks fellas. Any parts that are hard to find for this tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 7:23am
AC720Man, as the hydraulic pump gets weak, the pump will stop working intermittently, especially when the tractor has set unused for a period of time. Infusing some hydraulic fluid usually will get it working and it will keep working as long as the tractor doesn't sit for an extended period. It progresses (regresses) until the pump won't work at all. Then, it's time for pump replacement.
Thendrix, the 160 was built for AC by Renault, with a 3 cylinder Perkins diesel (I believe they use the same engine as the Massey Ferguson 135.) Some parts are readily available, but some parts are quite hard to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 11:45am
My 160 has 7,500 hours on it and the original hydraulic pump. It will at some point need to be replaced, they are still available. Some parts are difficult to find. The plastic tube screen at the rear sump is NLA and is vital in keeping the fluid clean. I have a spare that I purchased from a parts tractor. I use the 3 pt and hydraulic outlets quite often especially in the summer. Winter time feeding with a carrier on the 3 point and have no issues with it not working. Maybe I’m just lucky that I have a good one.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 1:37pm
Never believe 500 hours on a 50 year old tractor!  Could have stopped working, unhooked, or replaced in the past.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 2:55pm
AC720Man Agco shows Part # 72074423v strainer screen for 84.47
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 3:11pm
Unless they are making them again, 2 years ago I was told by AGCO dealer they were NLA. Dealer search resulted in none available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 3:23pm
VERY few parts - new - are available.   Many moons ago the head of Deutz Allis was a guy who's brother in law was a big wig in  Renault - we did our best to see what they could do for us - he got canned before we got any results.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 3:24pm
that "V" at the end of the part number usually means it's part of their Vintage line of parts
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 7:04pm
If I didn’t already have a spare I would get one. My original is still in good shape.
This page was generated in 0.463 seconds.
