Cold
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Cold
    Posted: 13 Jan 2024 at 8:49am
Minus 32 here this morning, with 66 below wind chill. But hey, we are going to reach a high of minus 18 today. Thank God, this is going to be sort of a short lived cold snap.
Darrel
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 9:04am
we started at 26 and is now 21 with high wind warnings falling temperature then staying in the teens till Wedsenday up to 20 and staying around that till the 26 the warming up above freezing here in Ohio. Sure hope yoour weather doesn't fall into here.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 9:16am
Been -40 here for the last few days.  S'posed to start warming up to about -30 tomorrow. Furnace has been generating lots of dollars for the gas company!!
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 11:15am
Darrell and Alberta, I don't know how you tolerate such temps. Do you have any livestock and where do they go during that cold weather if you do have? Hope your weather warm soon. You make Ohio not sound so bad.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 12:15pm
Have relatives in Ohio. Power was out 5 hrs this morning
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 1:30pm
man!! if it were to get that cold here,,, I can't begin to imagine the hard water problems I could have! it's like 10-12 degrees now with chill at bout -20, thats darn shore cold enough for me, not gonna get above 25 degrees until Wednesday...oh,,, did I say I don't like cold weateher??....
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 3:02pm
Yes, we have livestock. Be sure that they are out of the wind and fed well and have water to drink. Straw to bed down in. When you look at them, you wouldn't know it to be any different for them then when it's 20 above. They have the tolerance bred into them. They been out in it for hundreds of years. As for us humanoids, we spend a little more then most on Insulated overalls.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 3:22pm
yeah, I feel sorry for the animals....
what part of 'global warming' is this minus temps anyway !!!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 5:12am
-19 here currently, pretty darn cold for this part of the world!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 6:29am
-9 here this morning, uncommonly cold for our region.  Wind whistling thru the fields has Wind Chill down around -20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 7:46am
Thermometer shows-14 and rather breezy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 8:37am
Just as dawn came on, dropped to -12 here.  Locals complaining of furnaces Not Keeping Up and steady running.  Tourism site for town run by a local he noted his old all brick home is only maintaining 60 furnace steady on set at 68.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 4:46pm
Finally got some snow on Friday - along with the cold , first time I even put plow on truck to plow church . Then 4 wheel drive went out AGAIN , front differential seems all the bolts came lose and case opened up .
 For some reason I replaced it last year and that was for broken case where bolts came lose on right side casting to differential bolts flange coming lose .
 To dang cold to even work on it in shop .
This getting old and cold weather just don't mix , and laying on the floor in shop working on a truck is getting hard also - to hard to get back up once down there .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 5:26pm
Mine sits in the Shop here ALONE, 38 degrees in that bay, and unless I buy a heater NOT gonna be in there working either until warms some.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 6:36pm
-17 around 4:30am and -19 at 7:15am this morning. Not even going to venture outside till probably tomorrow afternoon.
That's All Folks!
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 6:43pm
Anything under -20 is considered Extreme Global Warming. Sorry but that's just an inconvenient truth.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 8:24pm
+35 in Tupelo today and the folks at Wal-Mart are wearing double pajamas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 9:49pm
Store manager getting married to command such formal attire?
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 2:09pm
Been -3 all day here, snow squall moving towards us. Just bitter outside in any breeze.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 2:14pm
Just passed through 1 degree so playtime again!!!  NOT!!!! Keeping my cheeks in the house for a spell longer.
That's All Folks!
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 5:12pm
40° here in south MS. Forecast low for tonight 18° and 16° tomorrow night. That’s cold for us. I know it’s nothing for some of the folks on here but cold for us. I spent 3 winters in ND so I do know a little about cold weather. I don’t see how you guys deal with it full time. Wishing the best for everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 5:52pm
GOOD heat,  BETTER Whiskey, and a Good WARM Woman!!!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 6:41pm
we will be minus 10 tonight as it allways does when it clears off after a storm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 6:46pm
Zero here this morning but the lake effect snow was pretty impressive. Three inches in a half an hour. Don't get the 30 below like you guys but would rather have it cold for the cows. Mud is hard on them . They seem to be healthy when its cold
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 9:16am
Every year that goes by I get a little better understanding of the 'snowbird' thing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 11:07am
Right There With Ya!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 12:04pm
We had 8 this morning with around 11/2" of snow it's up to 13 now I am blowing the snow off drive with battery powered leave blower, battery went died and am recharging it to finish. Was enough to  get the snow blower out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 2:56pm
We dont seem to get the snow too bad in the middle part of the state, the last 10 years.. Either goes north to Peoria- Chicago, or says south around St Louis... We do get the COLD..  About -5 the last few mornings, then +5 during the day... Dont like the COLD.. but dont miss that SNOW !
I have a 28 x 28 two bay work shop built into the hill side with 2 ft dirt on top.. Got two 9 ft bay doors on the front / insulated.. Stays 50 degrees in the winter and 75 in the summer.. Been working in there for the past 2 weeks !!   I bring in a small tractor / lawn mower / project and then spend  3-4 days on it... Then run em out and bring in another !  BIG UNS got to wait till March..
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 3:18pm
 Well,,I cannot lay claim to the cold temps like most of Ya'll got with them Minus zero temps,,,but we have been getting our share of 15* overnite temps and you add some 8-10 MPH breezes and it gets to be some Brutal  suffering,,,!!
 Sure does make Florida look good,,,,,Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2024 at 3:20pm
 Hey Steve,,you got any room in your warm shop for one more,,,,LOL
This page was generated in 0.101 seconds.
