7060 hydraulic filter change problem
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hydraulic filter change problem
    Posted: 12 Jan 2024 at 5:36pm
Got a maroon belly 7060 that I’m changing the hydraulic filters on. Changed the right side first and had no problems, went to change the left and it appears to want to dump every last drop of oil out of the system when I pulled the filter out I put the cover back on and here I sit, wondering what to do next, is there a check valve that is not functioning or did I do something wrong when changing the right side? I have changed the filters on this multiple times since I’ve owned it and never had this occur. Thanks for any help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 5:44pm
Personally, I've never had it happen, but it sounds like the "spring loaded door" ain't working. 17 gallons of oil will continue to come your way.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 5:52pm
You might want to get three clean pails and pull the three drain plugs underneath first, that is if you’re wanting to save the oil. It is a dirty job.
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 6:02pm
"Never had that happen?"  I'm surprised at that response. I've seen it more than once. And yes, the door "ain't workin". Only solution here is drain the tractor then pull the left filter and deal with the issue.
I learned to never trust the baffle. I remove the left cover ashort distance and give it a few seconds to see if the flow slows down before pulling it all the way out. If it doesn't, slam the cover back in and go to plan B. I use a fairly small pan when changing those filters. It's usually big enough when things go right, but when that door don't close it can overflow in just a short while.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 6:38pm
Been there, done that. It's amazing how fast a hog pan can fill up when that happens. You will need to drain it and remove the left hand filter housing from the rear end and then fish out the pieces to put it back together. I think that one piece threads back on and I would tack weld it, if it were me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2024 at 7:16pm
definitely a messy job, but got it drained and I found this in the filter housing.
This page was generated in 0.250 seconds.
