9 bolt hubs
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Topic: 9 bolt hubs
    Posted: 25 Oct 2010 at 1:24pm
Does anyone know where I could get a set of axle hubs for D19 to put on 9 bolt wheels?
Pullin With AC
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 1:59pm
Not Mine but just happened to see them, I think they are what you are looking for.
Dual Hubs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 2:02pm
That`s kinda what I`m looking for if it will fit the small axle on a D19.
Thanks
Pullin With AC
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 7:38pm
Been there and done that with a D-19. The D-19 has a 2 7/8" axle diameter if my memory is correct. I found a pair of clamp on hubs for a 9 bolt pressed steel rim from a Massey-Harris 44. The key in the hub and the axle are different so you will need an offset key. Not all M-H 44's have the clamp on hub for a steel rim. The cast center M-H 44's are different.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 5:40am
2 3/4" I think is right. Those on Ebay look bigger.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 6:23am
Thanks, I saw a set on a Massey in a salvage yard I`ll have to go back and measure them.
Pullin With AC
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 8:04am
