WD Hydraulic Fluid
KC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC/WD Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulic Fluid
    Posted: 10 Jan 2024 at 10:43am
I noticed my fluid is looking milky, usually does this with extreme cold. I wonder is the transmission casing is condensating causing this? Anyone else notice this?
TIA
I've got anal glaucoma, I just can't see my butt going to work today!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 1:24pm
normally it is caused by condensation.. unless it sets outside and is leaking around the dip stick / fill port...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 1:53pm
I always thought cold hydraulic oil aeriated a lot until warm making it look like water/moisture. An oil change will hurt nothing tho.
