WD Piston to Deck Height |
Post Reply ![]() |
LexAdmn ![]() Bronze Level ![]() Joined: 20 Sep 2022 Location: Missouri Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jan 2024 at 2:37pm |
Hello.
Curiosity question please. What is the piston to deck height on the WD? I bought the tractor a couple of years ago and the engine was very tired. So I decided to freshen it up a bit with new sleeves and a few other things. Now that the pistons are in (I am re-using the old pistons), I was curious what the piston to deck height should be. I am getting .773" using calipers. Pics attached. Thanks! KC ![]() ![]() |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5901 |
I read it as 0.073, or 73 thou. The first mark to the right of '0' is 0.001, or 1 thousandth of an jnch. The 10 is 0.010, or 10 thou The 70 is 0.070, or 70 thou. G |
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 460 |
. You may only be a few parts away from making that a W45 engine... Pistons, sleeves, crank, manifold. .
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21932 |
There's more than one piston for those engines. As long as they are all the same, you are good to go. It ran before, right ??????
You are correct on the dial, but if you look at the sliding rule, you can see we passed 7 but not 8. So we start at 700, then add the increments on the dial.
KC |
Yes, it did run before.
Perhaps I was comparing apples to ....well, something else. On another engine I did notice the piston sitting lower in the cylinder than mine. But I do know the pistons are different than mine but did not know about the pin height. Thanks. KC Edited by LexAdmn - 09 Jan 2024 at 5:10pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87939 |
You have a 4 inch stroke so the piston at the BOTTOM is about 4.770 inches from the deck.. At full TOP it is about .770 inches from the deck... You have some room in the head ( and it is domed) but let say that adds another .130 inch ( just a wild guess.
So you are going from a 4.9 inch ( piston to dome head) at the bottom to .9 inches when at the top........... 4.9 divided by .9 = 5.5 ... that would be your compression ratio.. It might actually be a little lower if the volume in the DOME is more than our "GUESS"............ New rings and liners will surely help, but part of your "LOW POWER" is the compression ratio... If it was up at 7.5 or 8 you would have more power. 4.6 Divided by .6 = 7.5 compression ratio ... so if your "deck to head" distance was more like .500 you would have quite a bit more HP.
No room in the head. The head is flat and valves protrude. Head gasket .060" I think.
OOOPS my bad... So its 4.770 + .060 or 4.830 ... and at the top it would be .770 + .060 or .830
So the compression is "about" 4.830 / .830 = 5.8 compression ratio.. Not great, but if the .770 was more like half inch, you would be at 8.1 compression.
Edited by steve(ill) - 09 Jan 2024 at 6:53pm |
Interesting numbers. Thank you for sharing.
KC
Post Reply ![]() |
