Interesting Diesel pump gov -Fordson
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: Interesting Diesel pump gov -Fordson
    Posted: 08 Jan 2024 at 9:42am
I found this interesting.
We had an old Fordson Major Diesel in the shop. It has a Simms inline 4 cyl fuel pump.
We removed the pump. It is driven off a slotted drive in the front like the old Buda AC engine with exposed drive and has one shut off cable attached. NO LINKAGE FOR RPM TO GOV.  There are 2 lines from the intake manifold, pre carb like butterfly valve in the intake and post butterfly valve port and line.  They go to the front of the pump. Low and high idle are set via carb butterfly valve in the intake that is connected to the throttle lever. I am sure some of you old hands have seen this, but it is new to me.. Harry Ford's Son must have had a better idea, he thought.  Still a little perplexed on the operation. Any other diesels use this system ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2024 at 11:06am
Hey Tim
I sent you a PM with my cell number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2024 at 12:15pm
called, got full mailbox :-)    sent you a text - call my cell.
