6000 series air conditioning |
sllimec47
Joined: 01 Jan 2024 Location: Massachusetts Points: 9 |
Topic: 6000 series air conditioningPosted: 08 Jan 2024 at 8:03am |
I am looking at a 6060 with a factory cab. It doesn't have air conditioning. Is it true that all of the components are factory installed in the cab? Does any one know of a kit available to add the rest of the necessary pieces?
Thanks
DrAllis
Posted: 08 Jan 2024 at 12:21pm |
All the cab components are in the upper roof area, yes. It isn't an "add-on" kind of deal with electric fans behind the cab. All you see is the compressor on the engine. Everything else is covered up when the hoods are on.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 727 |
Posted: 08 Jan 2024 at 2:38pm |
Ive never been around a 6000 series cab. We changed every piece of the air conditioning on a 8070. I dont see why it couldnt be done. Just have to find a supplier with the components. Maybe hy-capacity or ap air or walts tractors
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8995 |
Posted: 08 Jan 2024 at 10:49pm |
i wonder if you have one without air or it's missing some outer components and you think it doesn't have air....Was it an option? Never heard of a 7 or 8000 series with out air. why would the 6000 be different?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 09 Jan 2024 at 3:05pm |
According to the manual, AC WAS an option on the 6000 tractors. Actually if you look closely on the cover, it shows a 2wd 6080 with factory cab, but there is no AC compressor hanging on the left side of the engine. Mine has AC, but it does not work. There is a hole in the evaporator in the roof. Later models like mine have a 1 piece evaporator and heater core. Major surgery to get it out!
