CA Oil Filter Bracket Torque Specs |
dfwallis
Topic: CA Oil Filter Bracket Torque SpecsPosted: 07 Jan 2024 at 11:28am |
I coulnt find a spec for the bracket to block bolts (3 different manuals). I used 15ft-lbs, but that seems to have squished the cork gasket so much it cut and squished it out of alignment (new gasket ordered). I'll have to check the bracket for warping before I reinstall it (was not warped before, doesn't visually look warped now). Recommendation?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 07 Jan 2024 at 12:18pm |
I have never measure the "torque", but i would guess your 15 # was high.. Looking at the gasket as you tighten will tell you when to stop... I have used the cork before and i have also cut out fiber gasket to use... normally wipe a thin layer of RTV to seal it to the block. .... the cork probably gets less torque and more compression as compared to a fiber gasket.
you would be further ahead with a "torque" value of something like " snug to contact, then 1/2 turn of the wrench"...... if the gasket starts to squirt out the side or compress more than about 30% of its thickness, your going to far.
Edited by steve(ill) - 07 Jan 2024 at 3:39pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25270 |
Posted: 07 Jan 2024 at 1:14pm |
little 's' snug NOT capital 'T' tight....
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 07 Jan 2024 at 1:52pm |
That's not a real torque #...it's more of a "feel" and observe....I agree with small s snug. Tight enough it doesn't loosen and still seals. It has no pressure so a sealer is helpful.
15# don't sound like much but feels LARGE when tightening small soft things. Edited by SteveM C/IL - 07 Jan 2024 at 1:55pm |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 07 Jan 2024 at 2:31pm |
I've had better luck with just the ole "snug". I do what Steve suggested. I use a super thin layer (applied with my finger) of high heat Orange RTV on the block side, and just snug down the bolts till the gasket starts to move. Done! Steve@B&B
dfwallis
Posted: 07 Jan 2024 at 4:22pm |
I did use RTV. It's probably sealed, but since the gasket is cut strangely, I'm going to redo it anyway.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55293 |
Posted: 07 Jan 2024 at 5:09pm |
1/4 of an ugga dugga, at most!
