Broaching keyways |
| Author | ||
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: Broaching keywaysPosted: 06 Jan 2024 at 5:19am |
I’m wanting to learn to broach keyways.
Is a manual hydraulic press suitable for this? I need the press for other tasks but wondering about this? |
| Sponsored Links | ||
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Posted: 06 Jan 2024 at 6:26am |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25263 |
Posted: 06 Jan 2024 at 7:30am |
That is a GREAT video ! The guy is 'show and tells' HOW it's done. Almost makes me want go to buy $$$$$$ broaching kit and try it but, whew, got rid of my shop press last week !
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90840 |
Posted: 06 Jan 2024 at 8:43am |
a hydraulic press is SLOW.. Your only cutting out a few thousandths at a time.. A hand press is a little faster... BUTT.. it should be screwed down to the table to make it solid... I have not done much, but 50 years ago my dad use to do it often, just like in the movie above.
Codger
Posted: 06 Jan 2024 at 8:51am |
Minute Man, and DuMont are good keyway broaches for the occasional user and readily available via online suppliers. Keep a steady supply of lubricant flowing when you do this to prolong the cutter life. They can be expensive to resharpen, and you really don't want to break one tooth out as others follow quickly. A hand press will work but a smooth application of force such as hydraulic, or electric driven is best.
That's All Folks!
DaveKamp
Thanks(1)
Posted: 06 Jan 2024 at 9:06pm |
Tubalcain (Mr Pete) is Lyle Peterson... I have YET to meet him in person, but I hope to someday. His videos are great... they're the kind of how-to education that should be brought to boys and girls of all ages. So you can broach a keyway in a sheave using a broach kit, and if you go searching you'll find them for sale in many brands and grades. If you buy new, You VERY MUCH get what you pay for. If you happen upon an estate of a guy who has his own machine shop, you might get one for a genuine bargain. I don't have a broach kit... So I have to 'make due' with other methods where I can. I have accomplished it many other ways... the most frequent for me lately, is to rigidly mount the sheave in fixture on a horizontal shaper, and grind a tool to the width I want, and then advance it very slowly in until I'm at the desired depth. Another way, is to place it VERY FLAT on the bridgeport J, carefully locate and spot-drill a hole at the start point, then drill a small hole AT that start point, proceed THROUGH the sheave, and then chain-drill the path of the keyway towards the edge of the hole, then use the die-filer to open and clean it up. Keep in mind that a broach is basically just a file... it's just tapered to yield the cut expected. IF you have a file who's width is already correct (pronounced 'slightly smaller than') for the keyway you want, chuck some scrap steel in the lathe, turn it to match the ID of the bore... then put it in mill with a slitting saw, and cut a path down the length to accept your file... and use that as a guide to hand-file the keyway. IF you're REALLY lazy, make an adapter to fit that hand file into the clamp of your CORDLESS SAWZALL... I'm not proud of what I have to do sometimes, but I'll admit- I've taken a broomstick through the table saw to make a file guide for correcting a keyway in a chainring in a machine that I couldn't dismantle...
Thad in AR.
Posted: 06 Jan 2024 at 9:23pm |
That man makes the best videos. Everything I know about my lathe and mill I learned from his videos. As Dave says he’s a great teacher. |
nella(Pa)
Posted: 06 Jan 2024 at 9:36pm |
He helped me a lot on my 20" Lodge&Shipley that has an Allis Chalmers motor on it!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 07 Jan 2024 at 1:44am |
HAHAHA,,,,DaveKamp, don't we all take shortcuts sometimes to accomplish what we need? Even though in the long run it cost us a lot of extra time.... Ya gotta do what ya gotta do...
DaveKamp
Posted: 07 Jan 2024 at 7:56pm |
Well, Ted... it's like this... When you're a machinist, and you're somewhere, someplace, where your resources are limited, you realize that the sharpest, most flexible, and most powerful tool is 'tween yer ears... you figure out the rest... That's a Machinist.
Codger
Posted: 07 Jan 2024 at 8:18pm |
One of my grandpa's favorite sayings that I carry with me to this day is and I quote; "Everything's a tool, it's up to you to figure out how to use it".
That's All Folks!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 07 Jan 2024 at 11:55pm |
I have a set of broaches I used in the shop I was a millwright in , did a lot of sprockets and such . Has a set of bore sleeves to go into shaft hole , then depending on broach size for keyway shims to get proper depth .
Used a Arbor Press for doing the broaching . Now cutting the keyway in shaft was more of a problem and mill was used for that , or had a mill setup for lathe where shaft was held on tool post and cross feed used to move shaft . |
