Allis 715b bushings
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Topic: Allis 715b bushings
    Posted: 02 Jan 2024 at 10:00am
Finally got my 715b operational again.
Now during the winter months I think I will rebuild the lower bucket pins. The side with the large bolt instead of pin egg shaped the bucket side quite a bit.
Where are people getting pins and weld in bushings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2024 at 12:17am
I got stress relived shaft stock and made my own , bushings might try McMaster Car or even a bearing house - (look online) As far as work bucket you can try to add a shaft collar the size of pin and weld it onto bucket sides .
 I made my own from stock and drilled to size on my backhoe buckets that were worn .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2024 at 8:32am
Do you know the dimensions of the lower pins? I will get those and then try to bushing out from there.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2024 at 9:17am
KRAKMT: The diameter of the lower bucket pin is 1.995" - 2.001" and the length is 5.780"- 5.810".  These dimensions along with all of the pin and bushing dimensions for the Loader portion are found on page G-3 of the AC 715 Backhoe/Loader Manual dated 12/75.
The Part Number for the original AC Service Manual from which the above was excerpted is 9003463.
Good Luck with this project.  The AC 715 is a  great machine!
~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2024 at 9:25am
Thanks for the help from you both.
This place looks to have stressproof stock.
https://www.speedymetals.com/p-1597-2-rd-stressproof-or-equivalent-cold-finished.aspx
I would like to do the pins on the dipper where the dog bone attaches to the loader arm.
Can either of you give me that pin size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2024 at 11:19am
KRAKT: Yes can supply those too, send me a PM with an email - will photo the Service Page with all the Pin and Bushing dimensions.  ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2024 at 7:51am
Back working on pin rebuild.
Took me a couple months to get a windshield installed given the weather.
Would welding a 5ft stick of 2” Dom into the loader bucket pins- ensuring straight and square as bushings and then using 1 1/2 pins. Would this work? It would avoid the cost of line boring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2024 at 2:41pm
I would get an  estimate to have the egged out hole in the boom built up and line bored for a new bushing and be done with it.
Once done, and if maintained you would not likely be back into it in our lifetime.  My .02C fwiw.  ~ Orangeman
Edited by orangeman - 18 May 2024 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2024 at 5:37pm
When I stopped and talked to local shop on line boring the estimate I received was - “ that would be a lot”
Not many other options- I might have found one 3 hours a way. But using dom and going to 1 1/2 pins might also last me a lifetime.
Internet says a stick is $95 plus shipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2024 at 6:01pm
Cost on steel is almost beyond owning anything now . Son was buying pin material for his snow plows and has tripled for a length of full stick and a cutting charge added if he doesn't want a 20' length .
 Other thing one could do is buy round stock already with hole , then welding that onto what you need after boring it to accept bushing in size you want .
A idea of DOM tube -
https://www.metalsdepot.com/steel-products/steel-round-tube-dom
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2024 at 6:19am
There is a reason why when the original design was evaluated that a 2" pin was specified for the boom to loader bucket.  The solutions to undertake an egged out hole are multiple.  In the end - what needs to be decided is a repair solution relative to how the machine will be used and how it is to operate and importantly how much you want to sink into a machine that's approaching 50 years given current economics.  It might also be worthwhile to consider serviceability of the bucket to the boom geometry when using a smaller 1.50" pin and whether that will withstand the dead load and stress moment on the PIN stock selected.  A pin that is bent because it is undersized can be a pain in the _ss when there is a need to remove it - fwiw.
The article that follows is also worth a read relative to what you are considering - see link here:https://weldingweb.com/vbb/threads/707524-Backhoe-pinss
HTH's ~ Orangeman
Edited by orangeman - 19 May 2024 at 7:32am
