1966-67 D-15 Repair Manual
Alfred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alfred Quote  Post ReplyReply Direct Link To This Post Topic: 1966-67 D-15 Repair Manual
    Posted: 30 Dec 2023 at 8:43pm
Needed; 1966-1967 AC High Wheel Fork Lift Service Manual.  This machine is based on a D-15, 4 speed, clutch and has a hydraulic forward and reverse.  It has stopped moving and I believe it has something to do with a clogged filter and/or screen, the location of which is in question.  A picture from a manual would be a great help. Please text it to 609-847-0071. There are no obvious filters, I believe it is an internal deal.  Any help would be greatly appreciated.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 4:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alfred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 10:19am
Thank you so much, however the picture on the manual appears to be a newer model .  When I purchased mine a helper did some research and found that it was made in 1966 or 1967 and it is based on a gas powered D-15 tractor.  The Hydro component stopped working and I want to start with the simplest fix first.   I just need to know where the screen/filter is hiding without removing unnecessary parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alfred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 10:24am
I don't know the actual model number.  The plate is missing or painted over. I have not found it.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2024 at 6:49pm
I have a forklift like yours that I bought last year. Model would be I-60 or I-600. Mine would not go in reverse when I got it, due to slop in the shuttle clutch linkage. Forward/Reverse travel is done through a mechanical shuttle clutch, so I don't think that your problem is hydraulic-related.
