corn heads
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: corn heads
    Posted: 27 Dec 2023 at 6:53pm
can any one tell me the difference between a A630 head and a hugger head besides the price tag
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 8:21pm
Hugger heads fit Rotary combines.  A-630 fits L-M-G conventional combines. Nothing common in their design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2023 at 1:48pm
Isn't that an orange head? Lot of things to keep an eye on with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2023 at 4:02pm
A-series was the first black "adjustable" row width head. N-series same head but rotary combine offset main frame. Hugger is gear box head for rotary only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2023 at 5:59pm
what I have is a 630 head fits late N series have it on a R-5  it dosent have the extendable pto shafts it has a shaft and 3"  couplers you slide to couple shafts  its a black head
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2023 at 10:28pm
You have a N630 head that someone put the wrong decals on/ swapped end hoods with a A series.
Hugger is essentially taking what is good about a Deere 40series (enclosed gearbox row unit) and the Black frame (A/ N series) agressive gathering chains, etc. and combined it to make a really good header.
The black frame is a high maintenance header, however in down corn it has pretty hard to beat performance wise.
No more than its worth resale wise, Id keep it around for down corn and try to buy the hugger for your main header.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
