WTB 7060
JTA FARMS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTA FARMS Quote  Post ReplyReply Direct Link To This Post Topic: WTB 7060
    Posted: 23 Dec 2023 at 8:41pm
WTB 7060 Black Belly power shift with long axles. Any condition running or not.
Call 724 422 0687
Edited by JTA FARMS - 23 Dec 2023 at 8:43pm
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 7:37pm
I have red belly powershift 7060 I might  part with. It has a new radiator, new 6 blade fan, water pump, all new A/C, [side mount compressor] 4 95% 20.8 x38 Firestone radials, [axle mount duals, all powershift wheels], 95% tri-rib front tires, and new silicone heater hoses to top of cab. I also changed the bypass oil filter to spin-on and fuel system to dual spin-on filters with an electric pump. It needs a new exhaust manifold [cracked], and could use the interior redone. Hour meter hasn't worked since I've owned it, guessing 4500 hours. I'm probably too far from you but it's worth a try?                                                   Edit to add: I also rewired all of the lights[and added lights] with relays to take the load off of that expensive light switch.
Edited by lentsch - 01 Jan 2024 at 9:26pm
WD,D15,190XT,7000,8010x2,7060,8070
This page was generated in 1.721 seconds.
