WC With Oil Pressure SLOW to come up..... |
Post Reply |
OldAC
Bronze Level Joined: 01 Feb 2018 Location: Rural Michigan Points: 175 |
Posted: 22 Dec 2023 at 8:20am |
I have a WC that the oil pressure is very slow to come up. Its great oil pressure once it does, but its much slower getting there then my other WC's and WF. It has the fram loose pack filter on it with the proper tube. It almost seems that the oil all drains out of the filter and dosn't show much pressure till it takes while to fill again. Thoughts?
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80171 |
To drain backward, you normally have a small leak on the outlet side of the pump..that lets air in and the oil leaks back thru the pump into the crankcase... It could be internal at the pump fitting where you can not see it... .. but could be external..
Look for any damp spots in the filter / o-ring area... oil tubing fittings ... anything that could be a VERY SMALL damp spot that could mean air leaking BACK when shut down... You might want to remove the filter, clean the o-ring , inspect the seal and reinstall... just a possibility.
Edited by steve(ill) - 22 Dec 2023 at 8:28am |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8159 |
If you shut it off and restart it does it come right up to pressure?
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11744 |
I'm wonderin' if the oil pickup tube is partially clogged. Might be worth droppin' the pan and doin' a little invesagation..Sorry, that's Jersey talk for investigation. The ole' girl might need a little clean up in the old oil pan..I dropped the pan one day in my WC. Didn't know it weighed about 45 lbs with all the muck in it. Almost clobbered ma'self in the head!.... Steve@B&B
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3487 |
way overfill it like a gallon over full and see what it does , if it commes up faster i think you are sucking air some where between the pump and sump my c had a hair line crack in the sump tube up real hight and would struggle to get preasure
HudCo
prove your gauge
Post Reply | |
