Pictures of Hydraulic Lines #1
J. Larsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J. Larsen Quote  Post ReplyReply Direct Link To This Post Topic: Pictures of Hydraulic Lines #1
    Posted: 21 Dec 2023 at 4:16pm
This shows the line coming out from my hydraulic pump, going back to the control valve that operates the 3 point.  The LH quadrant lever is hooked up, but has no affect on anything.  I don't have any luck trying to get more than 1 photo per post, so I will post the other 2 photos on 2 other posts, and just look to see if my hydraulic lines are hooked up correctly.
Thanks,
JL
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2023 at 10:43pm
Your plumbing is a mess. I don't know what the guy was thinking who changed everything to that . The 2 hoses originally from pump to cylinders does the same thing without the MESS!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 7:20am
I think the poster needs to raise the left lever clear to the top, let out the foot clutch and move the spool lever between his legs one way or the other and see what happens. Make sure the system is FULL of hydraulic oil !!!
Edited by DrAllis - 22 Dec 2023 at 7:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 8:33am
Your hose goes from the PUMP back to the valve.. Take the hose off at the valve and put into a bucket... Start tractor and see if there is any PUMP  OUTPUT....... Is your Quadrant valve controlling the pump ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote J. Larsen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 9:32am
The pump is putting out 2800 PSI.  By using the control valve, you can get the 3 point to raise up and down, so there has to be oil flowing.
If you look at the pictures on post #2 and #3, you see how the rest of it is plumbed.
What I would like to see are some pictures on how it is plumbed from  the factory.
Thanks,
JL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 9:43am
An Owners manual would help you greatly. Good pics in it.
Edited by DrAllis - 22 Dec 2023 at 9:43am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 9:55am
