Mounting spray tank on 7020
GleanerOne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GleanerOne Quote  Post ReplyReply Direct Link To This Post Topic: Mounting spray tank on 7020
    Posted: 19 Dec 2023 at 9:56am
I’m looking for ideas on mounting a spray tank on the front of my 7020 probably a 200 gallon maybe 300 anybody have pics if they have done it Thanks
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 10:29am
Not mine. Here's a link to a 8030 2wd with 100 gal tank mounted in place of front weight bracket. Probably an ok layout per a 100 gallon tank. A 200 or 300 gallon tank mounted way out front, probably exceeds your 7020's (or any tractor) 2wd front steer axle / spindles? Possibly mounting 2 100/150 gallon tanks further back on engine side frames could transfer some of it's filled weight to rear axles?
Again not mine. Here's a link to an AC 7000 that shows larger side mounted sprayer tanks.
