7& 8000 series block heater
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: 7& 8000 series block heater
    Posted: 19 Dec 2023 at 4:39am
Does anybody know how many watts the 7000 and 8000 series tractor factory block heater draws
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 6:44am
750 watts is all.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 7:27am
AGCO has it listed at 1000 watts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 8:09am
Thank you. I want to get a litte generator to warm them up when they are out away from the shop big enough but not to big
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 8:17am
Maybe the 750 was for a 301. It isn't much for engine size.
YZfarms1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YZfarms1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 9:46am
I just replaced the block heater in my 7080 last week.  It was so tight I had to use a 3/4 drive breaker bar, along with a section of pipe to remove the old one.  I got it done.  And the new one gets hot, indeed.
My 7080 restoration stalled this past summer, as I was busy with other things.  I am now back into it again...with several things to correct.  New seat.  New cab foam.  And get the fuel gauge to work.
Craig        Champaign, IL
