What do I have here
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: What do I have here
    Posted: 17 Dec 2023 at 1:33pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 3:02pm
The upper one looks like, what is used to put ‘tags’ in calf or cow ears.
The bottom, maybe a pruning shears of sorts.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 3:30pm
Lower is a set of nips for trimming sheep hooves
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 4:57pm
That makes sence.
Sheep, cows and pigs all been here at one time or another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 5:05pm
I was going to say 2 hand tools between a pair of gloves but that'd just be silly..so I won't.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 5:55pm
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:08pm
old post but WTH.
top tool is for installing metal eyelets in leather straps/sheets, there's a matching tool to put a hole in the strap, then you lay the eyelet in the hole, and put the tool in place with the straight wall of the eyelet on the point, and when you squeeze it into the hole, the "Hole" side of said tool holds the eyelet in that radial groove and keeps it from collapsing, the straight wall of the eyelet slides over the point of the tool and is expanded outward and back, crimping the eyelet into the leather, and making the hole completely surrounded by metal, with the point going into the hole for clearance
My Dad had a couple, I used them as a kid to repair the belts on overshoes and adding lacing holes in boots etc.
ETA: I had a brain fart.  the eyelet sits the other way.  I have corrected my comment.
Edited by nanuk - 22 Oct 2024 at 9:55am
AC7060Pd 1975
This page was generated in 0.054 seconds.
