Farmall AC Model C?? Seller says factory... |
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 690 |
Topic: Farmall AC Model C?? Seller says factory...Posted: 13 Dec 2023 at 6:39pm |
Strange AC Model C seller says is factory experimental Model.
dfwallis
Posted: 13 Dec 2023 at 8:54pm |
Strange is right! :O
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 13 Dec 2023 at 9:49pm |
does anyone recognize the front bolster off of another tractor ? Where did it come from ?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55288 |
Posted: 14 Dec 2023 at 4:22am |
got a picture of the serial no?
LionelinKY
Joined: 12 Sep 2009 Location: Radcliff,KY Points: 699 |
Posted: 14 Dec 2023 at 4:25am |
Steering support and shaft looks like a Farmall B/BN so guessing front bolster is same.
DrAllis
Posted: 14 Dec 2023 at 5:32am |
Homemade creation, although pretty nice.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 14 Dec 2023 at 5:55am |
He's had that on Facebook for a while. I've asked more than once for documentation it's an experimental and he's never provided it. $4,500 seems steep for something he can't verify. AaronSEIA
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 14 Dec 2023 at 7:36am |
Never seen a Farmall bolster like that
steve(ill)
Posted: 14 Dec 2023 at 8:10am |
thats my point... if it is a "one of a kind bolster", he has that going for him... A serial number that it "ODD" or very low would help his cause.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 14 Dec 2023 at 9:57am |
Pre-production C tractors had hand brakes from the photos I have seen.
Fred in Pa
Posted: 14 Dec 2023 at 12:21pm |
Story's are easy ,proving them can be a task .
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 363 |
Posted: 14 Dec 2023 at 1:39pm |
I'd like to get a closer look at the step.
dfwallis
Posted: 14 Dec 2023 at 3:32pm |
Looks similar to aftermarket steps I see that bolt to the cross beam in front of the operator area by the clutch.
Brian G. NY
Posted: 14 Dec 2023 at 4:27pm |
Pictures of this "C" were posted here by "JerryMI" on1/15/07. He stated that it had A-C casting numbers. Although the post generated quite a lot of interest at the time, no one was able to say what it was.
I haven't seen a posting by JerryMI in many years....does anyone know whether or not he is still around?
KMAG
Posted: 14 Dec 2023 at 5:25pm |
Seller is in MI - so likely same tractor.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 14 Dec 2023 at 5:39pm |
Pretty strange, but different! I'm havin' a problem with the steering shaft as long as it is, there is no support at the steering joint. I'm wondering how that steers without binding up. The only support for the steering is at the steering wheel. You would think there would be a steering support at least at the bellhousing area.... Weird.... ![]() Steve@B&B |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34628 |
Posted: 14 Dec 2023 at 9:09pm |
That is some heavy shafting in there, so probably no need for supports.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
steve(ill)
Posted: 14 Dec 2023 at 10:17pm |
Ii had the same concern Steve.. If this was a "factory" design, i would think a support bushing would have been installed under the engine oil filter area, on the bell housing..
Richardmo
Joined: 12 Sep 2009 Location: Rolla mo. Points: 1747 |
Posted: 14 Dec 2023 at 10:46pm |
As I was reading this I am talking to Jeremy on the phone.
I will Try to get Jeremy to reply. There was couple of these tractors built not just one. Edited by Richardmo - 14 Dec 2023 at 10:48pm |
