Factory Bin Extensions for a K
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Factory Bin Extensions for a K
    Posted: 24 Oct 2010 at 3:44pm
Is there such a thing as bin extensions for the K, like the K2 had?  I know that there is an overbin unloader, but I haven't been able to find one.  Thanks!
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2010 at 8:22am
Kevin,  The k gleaner was never offered from the factory with bin extensions.  There drive axles were not really designed for the added weight.  However that did not stop most farmers who just built their own extensions using plywood.  The K2 had improved drive axles for additional grain weight.  I think you could swap a set from a K2 if you want the galvanized look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2010 at 11:09am
I have thought about putting some home-made wood extensions on my EIII...not to increase capacity but so I can actually fill the bin up to rated capacity and not slosh grain over the sides going to the truck to unload.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Billoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2010 at 6:29pm
I have 2 Ks & they both have bin extensions.The one was on when I got it & the other one I put on.They are not homemade,they are galvanized.HTH Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2010 at 8:41pm
Bill, do you have an over-bin auger, or just the regular auger, below the top of the orginal bin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 10:50am
I have the orginal auger in the top of the bin.
